SailNet Community - View Single Post - Retractable Bowsprit DIY
post #26 of Old 01-09-2013
SchockT
SchockT's Avatar
Re: Retractable Bowsprit DIY
Originally Posted by chucklesR View Post
Joel, Barry -
I'm not taking digs at the C27, just passing on a concern.
I
There is a serious difference between buying a well engineered kit from the builder and a DIY. I'm also not taking digs at Joel's ability to engineer it out properly and safely.
Since the have the kit why DIY? Safety should never be suborned to budget.
The "engineered" kits you refer to typically use either u-bolts or rings bolted to the deck. Some kits I have seen bolt onto the anchor roller. A DIY project that utilizes the boat's stem fitting should be just as strong or stronger than those arrangements, assuming the stem fitting is not already compromised. The stem is one of the strongest parts of the boat, because it has already been engineered to handle the load of the forestay and a big genoa.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
