Old 01-09-2013
Maine Sail's Avatar
Maine Sail Maine Sail is offline
Re: What's Wrong With This Picture??
Originally Posted by Brewgyver View Post
BTW, and unrelated to your pop quiz, the indicators are either incandescent or neon, not LEDs, and just need a few turns of white electrical tape on the black wires connected to neutral.
Those are neon indeed because it is an older boat and I did not replace them with LED as all were still working. You also can't be fooled by the "look" of the indicator light. The manufacturers of those indicators offers that same indicator light style in LED, neon and incandescent. Most every new AC/DC panel ships with LED indicators so I am just used to saying "LED".. I also generally replace neons with LED when dong a panel rebuild and some neons are shot...
The neutrals were tied into a white/neutral wire running back to the neutral bus and the reverse polarity got a green pig tail where it heads off to the grounding bus....
______
-Maine Sail / CS-36T
