SailNet Community - View Single Post - Retractable Bowsprit DIY
post #31 of Old 01-09-2013 Thread Starter
Joel H.
Re: Retractable Bowsprit DIY
Originally Posted by jameswilson29 View Post
If you were to design your own sprit, a great feature would be an articulating sprit with the sprit pivoting around the stem area and a curved track on the aft, so you could position it to the gunwale on either leeward side when flying the spinnaker, thus gaining additional valuable projection of the pole to windward.
Wow, that would be trick.
Though on my Cat. 27, if you draw a line parallel to the centerline, between the stem fitting and the foreword pulpit rail stanchion, there isn't a lot of cross-section there. So I don't think I can get much more swing to starboard, presuming I mount it on the port side, than it will take just to get it to intersect the C/L of the boat at a decent projection. That was one reason the teardrop cross-section of the spar, I have, seemed so "ready made".
Thanks for the thought James.
Next time I'm down at the yard I'll check that possibility out.
Cheers for now,
Joel H.
Joel H. is offline
