SailNet Community - View Single Post - Reefing a headsail???
post #26 of Old 01-10-2013 Thread Starter
deltaten
deltaten's Avatar
Send a message via Yahoo to deltaten
Re: Reefing a headsail???
Thanks Rich;
I'm having some trouble digesting the text stating; " The LP defines the sail size in terms of percentage increase beyond the J measurement as in the following examples." with the chart immediately below. It shows, under the "LP" column, a direct correlation to unit "J" past the "I" line.
It appears that roller furlers need the "LP" figure to relate the amount of sail exposed, as that's the direction of reduction; but regular (geometric term) foresail calcs rely on straight "J" numbers.
Am I missing something??
Doesn't the "IJ" fore-triangle calc describe a geometric area potentially filled by a headsail at 100% (not necessarily the actual measurements)? As I was led to believe, the increase in percentage was a function of the amount of the (base/"J") jib triangle passing the mast (height/"I") of the theoretical/geometric right triangle??
deltaten is offline
