Re: San Juan 24
Originally Posted by bobmcgov
Sloop: IIRC, the SJ24 has a deck-stepped mast with hinged base plate, right? It's a fairly lightweight spar & only 3-4' longer than the rig on our SJ21, which I can walk up with one hand. It's usually ten minutes from hitting the parking lot to mast-up on our boat, Then another twenty minutes sorting out the lines.
I don't know about the hinged step on the 24 but the 21 was designed as a trailerable, the 24 was not.
I owned a Kirby 1/4 Ton for years - it was a 26' development of the 24. I would not have considered dropping the 33' rig without a crane.
The bottom line here is that the 24, while being transportable without heavy equipment like a semi to haul it, is NOT a trailerable. It needs to be regarded as a "big boat" in that regard.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
