SailNet Community - View Single Post - Cool, soft way of attaching jib sheets
post #11 of Old 01-12-2013
heinzir
Junior Senior
heinzir's Avatar
Location: Lake Minnetonka (near Minneapolis, Minnesota)
Re: Cool, soft way of attaching jib sheets
Originally Posted by BarryL View Post
Hey,
Why not just use a cow hitch / larks head?
Barry
A cow hitch is fine if the sheet does not need to be removed/attached quickly and easily. You may want to use the same sheets for several different sails, in which case a soft attachment that is easy to connect/disconnect is ideal. Another scenario would be if a hank on jib is equipped with reef points; you can move the sheet up to the new clew. And thirdly, you can remove the sail (for trailering, for example) and save setup time by leaving the sheets rigged through their blocks and cleats/stoppers.
My boat fits all three of the above situations. As the saying goes, "different ships, different long splices."
Henry
Chiquita - 1974 Macgregor Venture of Newport 23
heinzir is offline
