SailNet Community - View Single Post - Electic Bilge Pump Installation
post #5 of Old 01-13-2013
tommays
tommays's Avatar
Re: Electic Bilge Pump Installation
In owing J24s going back to 1981 and electric pump was against class rules due to worries about moving water ballast
The only way for a J24 to leak is rainwater down the mast and in the worst it ever got after and epic rain/hurricane was about 8 gallons
Fast forward to 2012 i have a Cal 29 with two electric bilge pumps one in the low section of the bilge (its great having a boat with a real bilge ) on battery A
And one in a high section of the bilge on battery B which prevents the second pump from ever getting wet unless something really bad has happened
Both pumps go to separate above the waterline through hulls with anti-siphon loops and valves (because when the boats heeled over they go underwater )
I am somewhat still at a loss as to how boats leak other than rainwater down a keel stepped mast or a bit from from the shaft log
The only time my pump runs is from the ice box melting
I also have the large collection of manual pumps and buckets and in my experience your only going to keep up with a fairly minor event IF the two good size electric pumps both fail
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
