SailNet Community - View Single Post - sextant practice
post #10 of Old 01-13-2013
erps
the pointy end is the bow
erps's Avatar
Re: sextant practice
I downloaded "Step-by-Step Sextant User's Guide" and ordered the Mark 3 sextant and the artifical horizon to practice on. Can anyone give me a brief primer on what I am going to have to do to correct for the fact that I am above sea level when taking my sights?
My recollection is that the altitude you're concerned with is your altitude above the horizon. On the sea, that's the height of you eye above sea level. If you were in a shore side building, using the sea as your horizon, then your altitude would need to be applied. But it's my recollection that there is no DIP correction (height of eye above water/horizon) when using an artificial horizon, but the angle of the celestial object you're taking your sight on will be half of the angle indicated on the sextant.
They used sextants in airplanes to get around in the old days with artificial horizons and altitude didn't play into it (IIRC)
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
