SailNet Community - View Single Post - Overpropped; What to do?
post #3 of Old 01-13-2013
jrd22
Courtney the Dancer
jrd22's Avatar
Re: Overpropped; What to do?
Sounds like you are severely overpropped. Your engine is doing the work it was designed to do at 80% of it's rated HP (push the boat at hull speed) at 50% of WOT. That means the engine is working almost at it's maximum (400 rpm below maximum rpm) to move the boat but only has half or less of it's horsepower to work with. Get the prop re-pitched, or a new prop, your engine will thank you (it will last longer and be less prone to blow a head gasket, etc). Call a reputable prop shop and ask them, they'll undoubtedly have horror stories for you.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
