SailNet Community - View Single Post - The future of the sailing world. Why are there so few young people cruising??
post #402 of Old 01-14-2013
Capt.aaron
KNOT KNOWN
Capt.aaron's Avatar
Re: The future of the sailing world. Why are there so few young people cruising??
Originally Posted by wolfenzee View Post
If you take a carvel plank boat stick it in the water sail it for awhile then cover it with fiberglass to fix the problems you end up with "rot held together with glue". But if in building a strip plank boat you finish it off with fiberglass (as in the case of my boat), you end up with a boat that has the advantages of wood, with out the disadvantages and the advantages of fiberglass with out the disadvantages......plus some of it's own structural advantages. I had my boat out 2 years ago, went over it from stem to stern....sound as a rock (while I was at it I added 3 layers of epoxy barrier coat).
BTW, the second owner ground off all the polyester based fiberglass and replaced it with fiberglass using epoxy resin. I have seen quite a few piles of fiberglass coated rot in the yard here, all of them were boats that had fiberglass put on "after the fact", not as part of the building process.
True true, My good friend has a cold molded Spray replica, made out of plywood and coverd with glass that is a little brick sh!t house. Man, that dude that stripped the original poly off the planks is probably still itchy. I bet his arms still have a tingling in 'em as well. Love to see a pic. of your boat, sounds like a beaut.
" Some are boat wise and some are other wise"
Capt.aaron is offline
