SailNet Community - View Single Post - Retractable Bowsprit DIY
post #40 of Old 01-14-2013
knuterikt
Re: Retractable Bowsprit DIY
Originally Posted by peterchech View Post
I see. So ur basically setting up like u would the symmetrical spinnaker, except you have one extra line, the tack line. (Foreguy/after guy is the same as guy and spin sheet, right?)
I have a usual spinnaker boom setup for dip poole gybe. (Topping lift, Foreguy/downhaul and Pole heel lift)
There are six lines on the sail;
The four standard lines for asymmetric (halyard, adjustable tack, sheet x 2 rigged for outside gybe)
+ guys x 2 attached to the tack (the furler in my case).
Sort of eliminates the point of a cruising asymmetrical though, which is to simplify downwind sailing. By the time I set this up for my cruiser, I might as well just throw up the symmetric and have less complication to deal with!
Don't know if I agree with you.
Setting the asymmetric.
-clip furler onto tack line & guy's (use soft shacles to attach guy's so they can also be rigged after the sail i set)
-clip on halyard
-From cockpit
-Tighten tack (done by hand) to pull the furler out on the end of the bowsprit
-Hoist
-Unfurl while taking in on active sheet
If I need to use the spinnaker pole (normally light conditions DDW).
-set spinnaker boom on mast
-Put the windward guy in the jaw if the spinnaker pole
-Adjust Topping lift & Foreguy
-Winch in on guy while easing tack
To gybe (can do the hole gybe w/o leaving the cockpit)
-ease the guy while winching the tack tight (cabin top winch)
-Stabilize the spinnaker boom using Foreguy & topping lift
-Execute a standard outside gybe
-rest pole if needed on new tack.
I use this for cruising, seldom sail straight lines - normally I sail different courses with the asymmetric up.
So this give me a wider usable angle in which I can use the asymmetric.
-No need to switch between spinnaker/asymmetric
-On less sail to carry and spend money on
-Fore deck work with boom only when I need/want it
Still, it allows deeper angles for those with asyms so it's cool in that sense. Eliminates the only advantage that symmetrical kites hav on the race course. I haven't seen one flown off a pole yet at the race course, but maybe I just haven't been looking hard enough. maybe I should pretend I invented the technique ;-)
As i wrote i previous post, there are short hand racers around here who use it for racing.
One reason you haven't seen it on the race course can be
-rating rules
-type of racing (windward / leeward favor symmetrical)
knuterikt is offline
