SailNet Community - View Single Post - Perkins 4-108 Fuel Injector Pump Leak
post #16 of Old 01-15-2013
PorFin
Seņor Member
PorFin's Avatar
Re: Perkins 4-108 Fuel Injector Pump Leak
For those of you who may need to get the injector pump off of and back onto a 4.108:
A ball-end hex wrench will likely save your sanity. The inner bolt is the one that is the RPITA, and unlike the outer two hex head it's a socket head screw. Double check which size to get -- the bolt itself is 5/16" UNF. My screw takes a 7/32" hex key, but most 5/16" socket headed screws take a 1/4" hex key.
________
'85 BYB Vagabond 39
PorFin is offline
