SailNet Community - View Single Post - Knock Downs
Thread: Knock Downs
post #276 of Old 01-15-2013
Daveinet
Daveinet's Avatar
Re: Knock Downs
If you can manage 2 wives, there is no storm you can't handle.
Owning a Hobie, I put foam in the mast, so it would float. It did prevent the boat from turning turtle. I've often wondered about an inflatable bladder that attaches to the mast that would inflate when it hit the water, in the same way a life vest inflates. This would limit how far the boat would tip, and make it much more likely to right. While some felt the rig would not handle it, Ian Farrier was in on the discussion and felt it was a valid idea. I have to think if the primary buoyancy was near where the shrouds attach, the load would likely be less than the initial impact of the mast hitting the water. Most of what you need is to prevent the mast from "digging in" as the boat is pushed leeward. I wonder if that type of design would have helped WingNuts or the 26X that flipped where 2 kids drowned.
Dave
RL 24 NEW to me April 25th 2014
AFC 17' 2+2 (sold in 2012)
Hobie 14'
Sunfish project boat
Sailing a large boat on a small lake is very tacky.
Daveinet is offline
