SailNet Community - View Single Post - Keel J bolt replacement in lead keel
post #23 of Old 01-16-2013
deniseO30
One of None
deniseO30's Avatar
Re: Keel J bolt replacement in lead keel
Originally Posted by Freerider View Post
I found this from a Don Casey article that was linked at the bottom, its a little reassurance.
" Except on radical race boats, keels rarely fall off. The reason is that a huge safety factor is nearly always designed into the attachment system. Nevin’s Rule calls for one square inch of bolt section for every 1,500 pounds of ballast. Both galvanized steel and bronze have tensile strengths of around 60,000 pounds per square inch, so if a builder follows this rule, the bolts attaching a 4,500 pound keel are capable of supporting 180,000 pounds—a margin of safety of 40 to 1. Of course, the static load increases with heel, and we can only guess at the dynamic loads, but in a recreational boat neither is likely to test or even approach such bolt strength."
Keel Bolt Concerns
Sounds good.. but when they go, it's the shoe that lets loose.. Like mid 80s Catalina 30s used plywood in there...
20-40 year old FG that's had water in if most of those years.. is not really all that strong either.
My last project!
deniseO30 is offline
