Old 01-16-2013
chef2sail's Avatar
chef2sail chef2sail is offline
chef2sail will become famous soon enough
Re: The lonely Avacodo...
The trick to avacados is the ripeness
I always try and buy Haas avacados. A ripe avacado will be a darker purplish green. It will have some give when you presh in on the skin, but will not be mushy. Avacados ripe at room temp. If you want to slow the ripening process put oin a refrigerator.
To cut one, wash the skin place on a paper towel and cut the whole circumfrence with a sharp knife down to the pit. Cut all the way around. grap the two pieces in either hand and twist. The avacado comes apart, one with the seed the other without it. Take the seed out with a spoon or pop your chefs knife it it and lift out. If it is properly ripe the skin pulls away, or you can run a large spoon next to the flesh and the skin, or you can skin with a paring knife. Slice and cube according to what you want then
Spray with olive oil and grill quickly with grilled golden pineapple rings if you want to try it a different way than most
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
