SailNet Community - View Single Post - Emergency leak repair
post #7 of Old 01-17-2013
chef2sail
chef2sail's Avatar
Re: Emergency leak repair
Wooden plugs, Stay afloat and marine tex. The foam sounds like a good idea.
I have two dewatering mechanisms attached also.
I my head I "T"ed off the hose with a ball valve which leads from the diaphram pump that pumps our shower sump. I have 20ft of coiled flexible hose stowed connected to this. in an emegency thatb hose will recah all sections of the bilge area.
I also have a similar "T" in place with ball joint from the thru hull which by raw water intake to the engine. I have a 30 ft hose with a threaded end which screw into this. I can then use the engine itself to dewater the boat. ( this is also how I winterize the engine on the boat also)
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
