Old 12-17-2006
hellosailor's Avatar
hellosailor hellosailor is offline
Labatt-
This is for ham licensing--it's not called certification. (Equipment gets certified for use, hams only get certified when two attending psychiatrists commit them.)
The exams remain unchanged, exactly as hard as they were six months ago. The only change is that you will no longer need to take Element1, the Morse Code test, for any/all exams.
Note that you cannot get a license that currently requires Morse, until *after* the change is official. If you take it before then, you will have to hold your proof of passing and then resubmit it after the change goes into effect, or have the examiners submit your test results to the FCC after the rules go into effect.
http://hraunfoss.fcc.gov/edocs_publi...C-269012A1.pdf
For the official annoucement on the FCC web site.
