SailNet Community - View Single Post - Heat Help
Thread: Heat Help
post #23 of Old 01-19-2013
Minnewaska
Re: Heat Help
The operating limit for incoming water temperature on my unit in heating mode is 40 -77 degs F. Outside air temp makes no difference to the unit itself.
I'm not saying it won't work at all below 50, but it does just run and run and run and puts out very weak heat. In 60+ water temps, it will cycle for a minute maybe.
The difference is most notable between early Spring and late Fall, where air temps are similarly low, but water temps are dramatically different.
Jeanneau 54DS
Minnewaska is offline
