SailNet Community - View Single Post - Help With Boat Selection
post #6 of Old 01-20-2013
chef2sail
chef2sail's Avatar
Re: Help With Boat Selection
I like all three also, the Crealock is definately a bluewater cruising boat. Replacing the windlass cabn be done on all the boats, Brokesailor could comment on the Crealock as he has one.
Electric Windlasses are nice features/I wont go into the positives They add a lot of weight ( Battery as well as wire if run back to most users battery compartment). They also draw quite a few amps.
We have a Simpson Lawrence mechanical windlass which works very efficiently and is very simple and easy to operate with few moving parts which can break. I single hand a lot and have no difficulty either releasing or pulling up the anchor with this setup. You can use it to pull up to the anchor as oppposed to using the electric one to do this as y put resistance to the notor ( you are supposed to power up tho you anchor with an electric one)
I have decided to stay with our mechanical one as I only have 90 ft of chain. If I had more I may reconsider.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
