SailNet Community - View Single Post - lightning advice
post #21 of Old 01-20-2013
chef2sail
chef2sail's Avatar
Re: lightning advice
Originally Posted by noelex77 View Post
The consensus is that grounding slightly reduces the chance of strike.
Grounding reduces the charges that can accumulate at the masthead and attract the lightning.
The effect, however, is very small. The only real practical effect is to reduce the damage.
Thats the direct masthead strike, we were hit by a side strike through the water. I agree, trying to prevent a strike may not be possible, Trying to minimize damage...not sure that works either, though I believe its important to give the lightning a path or two to exit or it will blow holes in things to find its way to exit. The question is can you really direct the exit or path of the elkctricity once its on board, or will it seeks its own path off depending where it entered.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
