SailNet Community - View Single Post - Bulkhead Replacement-Advice Needed
post #16 of Old 01-21-2013 Thread Starter
rhr1956
rhr1956's Avatar
Re: Bulkhead Replacement-Advice Needed
Update: Using the multi-tool I cut through the entire length of the tabbed area of the bulkhead. I went as deep as the blade would allow...about 1/2 inch. The bulkhead is "stuck like chuck"...can't get it lose. I'm wondering if when they tabbed it in, they let resin run down the gaps between the liner and bulkhead causing it to be "glued" in. Now I'm thinking of using one of those inertia slide hammers to see if I can bust it lose. What do you think?
rhr1956 is offline
