SailNet Community - View Single Post - Frozen rudder shaft Hinterhoeller 28
post #53 of Old 01-21-2013
PorFin
Seņor Member
PorFin's Avatar
Re: Frozen rudder shaft Hinterhoeller 28
Originally Posted by rbyham View Post
I still face removing old stuffing box just above rudder tube. Will likely angle grinder it off. Then I can see Shaft condition and go from there. Not sure if I have lower bearing. Time will tell.
Should go without saying, but...
Be very, very careful as you get close to completing your cut through the broken part -- you really want to avoid nicking your rudder post with the angle grinder (or whatever tool you choose to employ.)
Good luck and let us know how it goes.
________
'85 BYB Vagabond 39
PorFin is offline
