SailNet Community - View Single Post - Bayliner Bucaneer Cruise Speed Under Power
post #2 of Old 01-22-2013
kellysails
Puget Sound Pounder
kellysails's Avatar
Re: Bayliner Bucaneer Cruise Speed Under Power
What is the Max RPM you can reach with Wide Open Throttle while under load?
What is the Max RPM you can reach with Wide Open Throttle while in neutral?
If both are the same you might be under propped which at that point I would check with the boat yard to validate.
kellysails is offline
