SailNet Community - View Single Post - Getting ready to add shore power
post #15 of Old 01-23-2013 Thread Starter
jrophoff
jrophoff's Avatar
Re: Getting ready to add shore power
Originally Posted by btrayfors View Post
Can't see very well from that pic.
While it appears that the top two breakers are 20A each, the wiring seems screwy. For example, the white wire (neutral) coming off the second-from-the-top breaker goes to the buss bar. But, there's no white wire that I can see on the other side of that breaker.
What you want to see:
1. A breaker for the hot (black) wire....coming into and going out of that breaker;
2. A second breaker, mechanically tied to the first one so that they both are switched on or off simultaneously, with the neutral (white) wire coming into and going out of that breaker; and
3. A green wire going to the grounding bus....no breaker.
The black wire coming out of the first breaker then goes to power the other two breakers for outlets and for your battery charger.
Bill
Bill--
I attached a diagram. Let me know if I am getting the concept (sorry if I am not).
Originally Posted by boatpoker View Post
Forgive me for asking the obvious but sometimes the obvious is overlooked. So you must have an AC or an AC/DC fridge, correct ? Since we know you cannot connect a DC fridge to this panel .
AC fridge
File Type: jpg Screen Shot 2013-01-23 at 4.58.33 PM.jpg (42.3 KB, 19 views)
jrophoff is offline
