SailNet Community - View Single Post - Issues with Heating in Annapolis, MD
post #3 of Old 01-25-2013
chef2sail
chef2sail's Avatar
Re: Issues with Heating in Annapolis, MD
Originally Posted by Kraden313 View Post
Need some help! My husband and I live on our boat here in Port Annapolis. We live on a Hunter 410. We just moved to Annapolis from NC last October, so the issues we are having now are a first for us both. Not to mention we have only had the boat for about 3 years now. The weather here is about 18 degrees and hasn't been above freezing for the past week or so. Not to mention a little snow night before last and more expected today. We have a heating and cooling system installed on the boat which is really nice and we also use a space heater at the front just to help. Here's the problem.....as of yesterday, the back unit was not putting out heat. The thermostat read at 54 degrees; however it was set at 66. The front unit is doing the very same as of this morning. It is reading 54 degrees but is set at 66. Here are the things I have checked; the raw water strainer....which is fine and has water in it and is running....both units, which are not froze over and you can hear them running it's just not heating. What bothers me is that the water that typically comes out on the outside of the boat through the little holes (don't know what they are called) is NOT coming out! What could possibly be going on here and how can I fix this?? IT'S COLD!!!
Sounds like you have a reverse cycle unit vs a straight electric one. Once the water temp reaches 50 degrees your system will not be able to work efficiently and pull heat out of the water. It may damage it if you keep running it. You will need to find an alternative way to heat your boat in the very cold water times.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
