SailNet Community - View Single Post - Cockpit Centric Sailing
post #16 of Old 01-26-2013
bobmcgov
baDumbumbum
bobmcgov's Avatar
Re: Cockpit Centric Sailing
Problem with well seating on the bow isn't the people. It's the first time you stuff your nose into a wave. Now you have 700# of water onboard. Gonna take awhile to drain that out ... oops! just stuffed another wave. This time the boat doesn't come back up. It's bad enough when an anchor locker gets filled -- a whole forward cockpit? Ski boats swamp this way, & they have lots more forward buoyancy than a sailboat does. Foredecks are flat to shed water. Even a boat with bulwarks will spread the weight out thin, until it get out of the scuppers. A concentrated load of water, as in a lounging space, would be catastrophic. Scary enuf in an aft cockpit, which has better drainage options.
ETA: Lounge accomodations above deck level -- a bolted down sofa, eg -- are better, but then the weight is up high, the jib can't tack, and one sudden lurch & the bodies are flying. No, the human body can sit or sprawl almost anywhere. Back against the mast, wedged on a side deck, draped over a mooring bit. It's amazing how comfy a granite boulder can be, for the first couple hours. Or a snowbank. Most of comfort is in expectations.
Buccaneer18, Grainnia
SJ21, Diarmuid
Albin Ballad 30, Fionn
bobmcgov is offline
