SailNet Community - View Single Post - Drilling into mast & boom
post #3 of Old 01-27-2013
knuterikt
Re: Drilling into mast & boom
Originally Posted by Jimmy E View Post
Picked up new traveller and solid vang.
I'm am very comfortable with installing new traveller- filling old holes, drilling new, backer plates and so on.
I need to find a resource or two regarding the instal of my solid boom vang. I'm uneasy drilling into the mast without a solid plan. Any advice on procedure or steps would be appreciated. I wouldn't take issue with even the most rudimentary advice.
Read all the instructions
Measure twice - at least
If you work alone use tape or lashings to keep the bracket in place while fitting.
Drill the first hole (at one corner) if you are going to uses screws tap the first hole and fix the bracket in place (if you use rivets just insert a rivet (w/o poping it) in the hole to get the bracket aligned)
Make sure the bracket is aligned.
Make the next hole diagonally at the opposite corner, tap and screw .
If you are using rivets I would fix it in the two corners before proceeding with the rest of the holes.
Drill the remaining holes, tap the remaining holes.
Use a compound (Duralac/teffgel) to isolate dissimilar metals when you do the final mounting.
I have been told that I should install the vang with a rate of 80% compressed , with the boom at a right angle to the mast
That seem to be a bad advice...it depends of the cut on your sail.
From this http://selden.se/_download.cfm?id=66...95-854-SET.pdf
Hoist the mainsail, and sheet home hard whilst ensuring
that the Rodkicker does not ”bottom”.
Leave a little extra play when the boom is at its lowest position.
knuterikt is offline
