SailNet Community - View Single Post - C&C 29 - Mark 1 vs 2
post #13 of Old 01-27-2013 Thread Starter
FDR - thanks for the insight.
I've not had a chance to see the boat yet but I'll have a better handle on what to look for.
I've read a lot online and was coming to the same conclusion you have offered - that the boat sails well as long as you don't overpower.
Intrigued to hear your positive thoughts on the Atomic 4. I thought that might be a major sticking point. I'm hoping to boat has a fresh water cooling system rather than salt water - since it sounds like the salt water systems cause more problems.
I'm looking forward to checking the boat out shortly. I will likely do a cursory evaluation - then go back when the snow clears if it looks good under its cover.
mgb69 is offline
