SailNet Community - View Single Post - Cleaning bronze chocks
post #10 of Old 12-19-2006
sailaway21
Owner, Green Bay Packers
What ever method you use to clean them, you'll need to coat them to keep the shine. This can be as simple as a coat of varnish or some other product because without they will reoxidize quickly. If you elect to use a chemical on them, be aware that the biggest problem with doing so is applying the chemical only to the chock. Usually it manages to run onto things like your hull, where it does an equal job of removing things-like wax and the shininess of your paint!
sailaway21 is offline
