SailNet Community - View Single Post - Newbe with no experience buys big boat
post #27 of Old 01-28-2013 Thread Starter
davidpm
davidpm's Avatar
Re: Newbe with no experience buys big boat
Now to grill Glenn.
Are you sure your leaks were hull-deck joint?
I read your book very fast so forgive me if I missed some stuff but did you remove everything from the deck and rebed.
Even some handrails or blocks mounted to the deck can let in a lot of water.
Also 5200 is considered the wrong stuff to use for bedding above the waterline.
You want something that stays soft and is not such a powerful adhesive.
The idea is that that a super adhesive like 5200 will not allow any movement and will actually cause things to crack someplace else and allow water in.
Someone will reference the appropriate thread for your next boat.
davidpm is offline
