SailNet Community - View Single Post - How often do I need to replace my cutlass bearing?
post #10 of Old 01-28-2013
itsaboat
itsaboat's Avatar
Not to hijack a thread, but to play the counter argument, my cutlass bearing is tight. I mean so tight I can hardly turn the prop by hand in neutral. It's not new either. It came with the 1985 boat. We replaced the stern tube on last haulout and I had to hammer the prop shaft (with a wood block as a buffer) to get it back up to the flange.
Should I just motor around until it wears some? I'm a lake sailor with an easy in and out of the slip an dont run the engine much. Does rubber swell over time?
Pearson 27
itsaboat is offline
