SailNet Community - View Single Post - how do I remove the impellor housing from a yamaha 9.9? it won't come out...
post #4 of Old 01-29-2013 Thread Starter
peterchech
Re: how do I remove the impellor housing from a yamaha 9.9? it won't come out...
Yeah I'm concerned about opening up that gear box. The whole lower unit must have been left in the water at some point by the PO so there's corrosion everywhere, and I can't even get the prop shaft out because the seal between the lower unit and the metal retainin part is completely corroded. I might be able to bang it off eventually, but prob not without breaking the aluminum and then having to order new parts, again.
Can o'worms for sure...
I really only need to replace the seal, I wonder if there is some way of cutting it, wrapping it around the shaft then somehow gluing it back together therefore not having to get this stupid thing off in the first place?
Maybe I just need to buy the shop manual, which costs more than all the parts I ordered for this motor together unfortunately...
peterchech is offline
