SailNet Community - View Single Post - Lifeline stanchions
Old 12-19-2006
sailingdog sailingdog is offline
Just remember that the taller stanchions will have more leverage and torque when someone falls against them than the older, shorter ones did...and should have substantial backing plates, probably larger than what was previously used.
Also, don't use vinyl covered cables for the lifelines. Just use plain 1x19 stainless instead. The vinyl covers can help cause and hide corrosion problems. If you're going 30 inches, it might be worth doing three lifelines, rather than just two IMHO. It's a bit pricier, but some think it is worthwhile.
CS Johnson
makes a lot of different fittings for lifelines. Garhauer Marine has stanchion bases and such.
