SailNet Community - View Single Post - How often do I need to replace my cutlass bearing?
post #23 of Old 01-29-2013
chef2sail
chef2sail's Avatar
Re: How often do I need to replace my cutlass bearing?
Originally Posted by MedSailor View Post
Great info! Thanks everyone. My prop shaft comes out of the hull with an aperture, instead of a strut. It looks most like Ron's photo above.
I will be pulling the shaft so, I'll replace it this time in the yard.
MedSailor
Good idea. It will be a piece of cake then. Since you are pulling the saft are you placing stuffiing box with dripless ( do you have). If should at least take the oppertunity to replace the rubber bellows on the shaft inside the boat. How about the coupling? how does it look? will they have to hammer it when they remove it? May be a good time to rrplace it also. Not that expensive either. You have it all apart so look at it good. Also make sure the shaft isnt scored.
We replaced everything this year, since it was out as the major expense and work (labor) was pulling the shaft. New engine mounts, coupler, shaft, driplles packing, cutless bearing. Parts cost less than $500
Propeller Shaft Removal
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
