SailNet Community - View Single Post - Transmission output flange fell off Yanmar 2QM15 - Theories re: why?
post #21 of Old 01-30-2013 Thread Starter
JeffBurright
JeffBurright's Avatar
Re: Transmission output flange fell off Yanmar 2QM15 - Theories re: why?
Originally Posted by knuterikt View Post
When you push the flange onto the drive shaft - do you have a tight fit?
Or does it feel wobbly?
It would be a pain to put the flange back on to try now, but from what I remember, once the flange was pushed all the way in it was a tight fit.
Capt. Gary Randall, I'm with you that the flange is most likely just a softer metal that machined itself, as Faster said. Where I'm uncertain is whether this happened over weeks, years, hours? That would help determine to what extent this failure is a symptom of a larger problem.
JeffBurright is offline
