SailNet Community - View Single Post - I think I have found what I want
post #12 of Old 01-30-2013
CalebD
Tartan 27' owner
CalebD's Avatar
Re: I think I have found what I want
Originally Posted by minnow1193 View Post
It is the keel/cb version. Anyone know the weight of the centerboard? Wondering how much of the ballast might be from the cb, or if it is mostly in the keel and the cb is just fiberglass or metal.
I don't know the exact weight of the CB but it is definitely < 200 lbs and not a big factor in the ballast of the boat. The ballast is in the stub keel that surrounds the CB trunk.
Like Rob Gallagher suggested, find out if the propulsion from the 7.5 HP engine is a sail drive or direct drive setup.
In either case, I suspect that the 7.5 HP engine is a one lunger (1 cylinder) so make sure that all your fillings are well set in your teeth!
Everybody has one:
CalebD is online now
