SailNet Community - View Single Post - Sailors rescued 900 miles off shore..
post #12 of Old 02-01-2013
mad_machine
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: Sailors rescued 900 miles off shore..
Winter on the North Atlantic is one of the more unforgiving places to be. If you look carefully as most commercial ships, you will notice the draft numpers for and aft? Used to be (not sure if it still is) that the bottom most number would be labeled "WNA" as in... Winter North Atlantic.. Loading to this line would put the ship at her shallowest depth and giver her the most freeboard to survive the waves from the storms that churn this part of the ocean up during the winter.
While I have no problems with sailing across the atlantic.. it is not something you should do from late fall till mid-spring
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
