SailNet Community - View Single Post - Power Outlet Sizzle - Help Please
post #49 of Old 02-04-2013
Ajax_MD
Chastened
Ajax_MD's Avatar
Re: Power Outlet Sizzle - Help Please
I disagree. It isn't always that simple.
The boat is an '85 Catalina. The boat is nearly 30 years old, which offers plenty of time for age and corrosion to introduce extra resistance into an electrical circuit.
My assumption is that the OP is running over 80% of the rating for the circuit, at the end of a long wire run, the wiring or the contacts in the outlet begin to heat up, it melts down, causing the "sizzle" and now the outlet is out of commission.
As I said in my post where you quoted me, running at close to 100% of the circuit's rating continuously, on 30 year old wiring and equipment, is likely to induce extra heat, which would eventually cause a failure.
You make it sound as if electrical components don't at all to break down with age, especially in a marine environment, and that it's safe to run at 100% of a circuit's rating indefinitely. I disagree with that.
The "80% rule" not only applies to vessels, it applies to shore-side installations that aren't even subject to the constant motion and corrosion of the marine environment.
That's cool though. You be you, and I'll be me.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
