SailNet Community - View Single Post - Keel Bolts
Thread: Keel Bolts
post #5 of Old 02-04-2013 Thread Starter
Ajay73
Re: Keel Bolts
Originally Posted by CarbonSink62 View Post
I hope you meant to write 'iron' here. I'm not the expert, but I believe that the lead keels cannot have additional keel bolts added. They have 'J' bolts that are put in when the keel is poured.
I agree with the comment that this should not be done 'just in case', if there is no "Catalina Smile" there is no reason to sister the bolts.
My C25 has a small crack at the hull/keel join. I call it a "Mona Lisa Catalina Smile".
Ken
Ken, maybe I'm not clear. This "inspection" hole would be drilled shoulder to shoulder, so to speak, with an existing bolt but only down to the where the lead starts. I'm not talking about this boring being where I put the additional keel bolts. In this inspection hole I should be able to see a tiny bit of thread and determine if there is any crevice corrosion occuring in the area where the bolt goes through the laminate.
Ajay73 is offline
