SailNet Community - View Single Post - Keel Bolts
Thread: Keel Bolts
post #6 of Old 02-04-2013 Thread Starter
Ajay73
Re: Keel Bolts
[QUOTE=SloopJonB;985683] The only place they deteriorate is above the keel, either where they go through the hull (most common) or where they are visible in the bilge (obvious).
But that's why I need to inspection boring. Where they go through the hull is where I can't see whats going on. I could only see what the bolt looked like down to where it went started to go through the bottom.
Do you think 12" into the lead would be sufficient?
Ajay73 is offline
