SailNet Community - View Single Post - Engine over temp at idle
post #8 of Old 02-05-2013
Minnewaska
Re: Engine over temp at idle
Casey, I've been there and it has always turned out to be the impeller. The first gush of water was probably what was sitting in the exhaust. Pull the impeller and get a new one. It sounds as if you've unintentionally run it dry for a bit now. Clean out the interior housing of the pump with a scotch brite pad and load up the new impeller with glycerin. Overload it! You may also want to insure that your seawater strainer doesn't have an air leak.
Jeanneau 54DS
Minnewaska is offline
