SailNet Community - View Single Post - NMEA 2K Network Problems (Garmin GMI 10/Airmar DST800/GPS 19X (NMEA0183))
post #16 of Old 02-05-2013
arisatx
arisatx's Avatar
Re: NMEA 2K Network Problems (Garmin GMI 10/Airmar DST800/GPS 19X (NMEA0183))
Originally Posted by jsaronson View Post
you need to ground the power cable. put a meter on the wire going into the network to verify.
I would start here as JSARONSON suggests. Can you get a hold of Maretron's N2K Meter to test the physical cabling?
If not, if you have a DVM you should test as follows:
Maretron Support Knowledge Base :: How do I check the health of my N2K cabling before powering my network?
Regards,
Ted
V42#186
s/v Little Wing
arisatx is offline
