SailNet Community - View Single Post - Engine over temp at idle
post #14 of Old 02-05-2013
Minnewaska
Re: Engine over temp at idle
I still find an intake blockage to be the least likely, but good luck. Could happen, I suppose. If you don't already have wire reinforced clear hoses, you might consider replacing them while you're at it. Much easier to see flow when the engine is running and to eliminate the blockage theory.
Jeanneau 54DS
Minnewaska is offline
