SailNet Community - View Single Post - Ground Tackle For Chessie Mud
post #9 of Old 02-09-2013
chef2sail
chef2sail's Avatar
Re: Ground Tackle For Chessie Mud
This may be the most important thing you buy for your boat. It wont be cheap and take your time choosing. The new Gen anchors Manson Supreme and Rocna (Mantus is still unproved but looks promising except it is bolted) are far superior IMHO than other anchors as they can cover a wide range of bottoms. The set faster and reset fast if necessary. The weighted roll bar, weight distruibution and beveled tip help it dig in big time in most bottoms immediately. These anchors tuen and reset right away in tidal rivers/ switching fast currents like the Delaware or in the LI Sound. You should buy an anchor for many bottoms as I am sure you guys will eventually go coastal crusining an encounter them. Also the Chessie bottoms are really more varied than you think. Wye River- grass, Chester River leaves and thick black mud, Annapolis- silty, Sassafrass leaves and sandy. We have a Rocna 15 ( 33lbs) and it is the best anchor I have ever had bar none. It digs and stops the boat with a jerk before even backing down.
Cost- West Maine
Rocna 33 lbs- $345
Manson Supreme 35 lbs- $404
Before buying check the space of the bail over your roller to see what it will accomadate. Mansons shanks are wider and some have trouble, The tips should fit right under the bow point.
Also get on line prices from others and take to West marine as they will match prices. Same with the chain and line of the rode. I find the two superstores Annpolis- Hilsmere and Batimore Route 40 are good about this
Anchor chain and line- how much?
Rememeber in anchoring you need to add freeboard ( averages 6 ft) and high tide numer to find out actual dimensions when anchoring. For instance if you anchor in Chester River at 1 hour before high tide and its 19 ft, figure high tide it will be 20, fthen add freeboard= 26 ft. If you are putting out standard 7:1 in good wind thats 182 ft....30 chain and 150 line. assuming you will eventually anchor in water deeper than the Chessie, I know its shallow here, you should buy enough line so you wont have to eventually change out. I suggest 250 ft 3 strand. Thats the normal stuff.
No less than 30 ft of chain- it will help with the cantanary angle and it laying down when anchoring. More than 60 will require a snubber.
Find the specs of the gypsy for your windlass...either on line or call manufacturer. Some may have different sizes for the same model also. You want to buy either G4 40/43 or BBB, not just galvinized. You also want someone to professionally splice it for you.
Standard shackle with wiinding wire is the way to go... IMHO dont go the swivel route as it becomes the weakest point of the system.
3/5 chain + 5/8 line is good...but you have to find out what fits in the gypsy of the windlass. It will take both chain and rode. practice with your windlass in the slip so you can figure it out before anchoring, free fall, controlled anchoring so it doesnt land in a pile when it goes down and also practice what to do should it jam. Do not change you technique when raising the anchor, dont have the windlass pull you up or you will burn it out. Have the admiral slkowly motor upo while you power it up till you get right over it, then pull it up. Always use gloves Gardening type and throw them in the anchor locker, I have seen viscious anchoring hand accidents. Also you might want to invest in a washdown pump as the mud you bring up with a Rocna/ manson is incrediable and a testement to their holding power.
Take you time in buying this and get a good buy as well as system. Piece of mind and the ability to sleep safley are important. I have never slept better on anchor as with my Rocna, Also put Drag Queen on your apps.
Here are some online pricing
Anchor Lines and Chains
Gr 40 Windlass Anchor Chain
If you have questions PM me.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
