SailNet Community - View Single Post - Oh what to do? boat on rocks/reef/sand/mud
post #35 of Old 02-10-2013
MedSailor
Closet Powerboater
MedSailor's Avatar
Re: Oh what to do? boat on rocks/reef/sand/mud
Originally Posted by TQA View Post
OK here is my list. It assumes that I am in passage making mode.
Drop dink and fit OB aprox 200lbs.
Sound the area from dink using oar which is marked with the boat's draft
Layout kedge in direction of deep water and tension using cockpit winches.
Drop both anchors and all chain from bow. 2 x 50lb anchors and 400ft chain 770lbs.
Empty water tanks 150 galls 1200lbs
If it has not refloated the boat would be heeled over using a masthead halyard. [ I would use this strategy earlier if help was on scene or I had crew onboard. ]
The strategy of heeling the boat using a masthead halyard is the key to getting most boats off in my experience. Not bilge keelers or wings though !
In 10 years of liveaboard cruising I have helped in a number of rescues. A call on the VHF often produces a dinghy squadron.
+1. I tried a bunch of stuff and this strategy really works! I also like the idea of dropping the main anchor and chain to reduce weight.
I keep a leadline handy for sounding from the dinghy. I use it all the time.
MedSailor
MedSailor is offline
