SailNet Community - View Single Post - Coolant circulation issue - is the water pump working?
post #2 of Old 02-10-2013
dabnis
Re: Coolant circulation issue - is the water pump working?
You may have an air pocket somewhere. You might try running it with the coolant cap off. Some engines have a bleed screw, probably at the highest part of the block.
Paul T
dabnis is offline
