SailNet Community - View Single Post - Ample Power vs Balmar vs Xantrex
post #6 of Old 02-11-2013 Thread Starter
Re: Ample Power vs Balmar vs Xantrex
If you are trying to get to 100% with any alternator it is still going to take 10 hours +.. You will charge in bulk faster because you are not limiting the voltage when the alt heats up...
What you are looking to do with any alt is to cycle between 50% and 85% or so state of charge. If on a long motor run then you can get back closer to full but the bank will limit how much current once in absorption mode and this current limit will continue to decline until you are putting in less than 2% of capacity per hour...
Yes.. That makes sense.. But if I can remain in 'bulk' longer than a few minutes then we'll be much better off. As it is now we stop and shop every 4-5days and plug in to top up overnight with shore charger. If indeed we can recover 50-80 amps in a few hours of motoring I think we could lengthen that interval by a day or two.. or more... esp in areas where wind is a scarcity in summer.
We're looking at solar supplement too.. But one step at a time- no doubt like Maine we have areas and seasons where sun is less than reliable..
Thanks again
Faster is online now
