SailNet Community - View Single Post - Harken MkIV or Furlex 200s
post #11 of Old 02-13-2013
overbored
overbored's Avatar
Re: Harken MkIV or Furlex 200s
Could correct it being low with a toggle assembly and a few inch shorter headstay
I disagree with the thin plastic description. Harken is generally known for superior products. It appears yours is not installed correctly if you keep having the same problem
As far as the jam. And it happens to all furlers at some time. Which is easier to correct and fix....an open body drum or one which is closed
Raising it up will make the problem worse the top of the drum hits on the bow pulpit . its a Colgate 26 design flaw
"GOLD RUSH" PRINDLE 16
overbored is offline
