SailNet Community - View Single Post - Coolant circulation issue - is the water pump working?
post #10 of Old 02-13-2013
chef2sail
chef2sail's Avatar
Re: Coolant circulation issue - is the water pump working?
I would suggest that you use a special marine antifreeze as opposed to regular shell antifreze of thats what you are using, which is not poisonous to the environement, animals and humans, especially since you already said you have a leak, which goes to your bildge and then gets pumped out. Although it is major diluted it isnt good to have the ethalyene glycol which is toxic put into the water. Also some of the antifreezes have rust inhibitors different from car antifreeze.
Polar Preferred Marine Anti Freeze / Coolant
SIERRA® Antifreeze/Coolant
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
