SailNet Community - View Single Post - Harken MkIV or Furlex 200s
post #14 of Old 02-13-2013
chef2sail
chef2sail's Avatar
Re: Harken MkIV or Furlex 200s
We have the Harken Cruising furler (similar to MKIV but single groove and fatter foil) and the only issue we've had is occasionally, for reason's I've not yet been able to nail down, the furling line escapes the drum cage and locks itself, effectively 'jamming' the furler. It's only happened during sailing, never part way through a furl or unfurl. Requires a trip forward to straighten out. I suspect it happens at the end of an unfurl with too much slack in the furler line.
Other than that (and regretting not going for the full MKIV after all) the only beef is the crappy, slippery furling line supplied with the unit.
They have changed the line in the last two years. Keeping pressure when unfurling is important to prevent a jam as is cleating off the furling line once it is pulled out. That will help as we had the same issues.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
